Activity Forums Adobe After Effects Expressions Only show an object when the camera is within 45 degrees of it?
  • Only show an object when the camera is within 45 degrees of it?
    Posted by Unit_9 on September 15, 2007 at 12:44 am
    Hi all, 🙂
    I want to fade in a series of images when the camera is within 45 degrees of facing them. I’d also like it to fade-in the image the closer you are to facing them – so 45 degrees away or more would be 0% alpha and 0 degrees (directly facing the image) would be 100% alpha.
    Can anyone help me with this??
    Dan Ebberts replied 19 years ago 2 Members · 1 Reply
  • Dan Ebberts
    September 15, 2007 at 4:10 am
    This should do the trick:
    C = thisComp.activeCamera;
    v1 = toWorldVec([0,0,-1]);
    v2 = normalize(C.toWorld([0,0,0]) – toWorld(anchorPoint));
    angle = radiansToDegrees(Math.acos(dot(v1,v2)));
    linear(angle,0,45,100,0)
    Dan
