Activity Forums VEGAS Pro only seeing black
  • John Rofrano
    June 10, 2009 at 10:53 am
    > If it is working would you suggest that I seperatly render my projects from the mpeg 2 fomat with the chroma key to DV AVI and then compile all of thoes project files into one main project file and then use the make a movie feature to save it as dvd format?
    Yes, that seems like a good approach. This way if you need to do more work on it you have it in DV AVI format which works a lot smoother in Vegas.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chris Nickila
    June 10, 2009 at 1:50 pm
    Ok, thanks again for all the help with this. I appreciate it.
  • Chris Nickila
    June 10, 2009 at 1:51 pm
    Thanks for the help on this one. I will keep this in mind if I run into more issues.
Page 2 of 2
