Activity Forums Maxon Cinema 4D Only render part of scene
  • Only render part of scene
    Posted by Chris Joyce on January 13, 2011 at 3:59 pm
    Hello
    I am not sure if this is possible or not. I am working to a tight deadline and need to shorten my render time as much as possible.
    Scene: I have created a 3D word in which the camera animates around. Its zoom in on a object which has a hole in and the clients video fades up in the hole. The video will play for about 30 seconds but there will be still be a slight camera movement. As I am adding the footage in after effects I was wondering if there is a way to render the scene but when the video would come up I can cut out the middle so it doesn’t render my world behind it. Hope that makes sense.
    I am trying to fill the hole with a solid that has a an alpha channel material applied but that doesn’t seem to work! Any ideas?
    Brian Jones replied 15 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    January 14, 2011 at 12:16 am
    put your solid in the hole but use a Compositing tag to assign an object buffer to the solid and use the alpha channel it generates (Multipass)
