Activity Forums Adobe Photoshop Only Ps CS4 won’t launch in Windows7
  • Only Ps CS4 won’t launch in Windows7
    Posted by Mike Prindle on December 27, 2009 at 9:27 pm
    Anyone having this problem or know solution? CS4 Prod Prem DVD installed fine months back in Vista Prem x64. Recently I did a clean install of 7 on a new bare drive which went well. But when I tried to install the Prod Prem Suite in 7, error msg was returned saying Photoshop x64 and Flash failed to install successfully.
    I checked Program Folder (C-drive)& found Ps x64 files there. But when I tried to launch Ps, an error msg returned saying some files could not be found in directory. However, all the other appls in the CS4 Suite installed fine and launched okay: Ae Pr, Sb, En, etc…
    Adobe Support was clueless after researching these symptoms and suggested maybe the DVD disks were bad. Doubt it since it installs on Vista. Help!
    Sager NP-9262 Notebook, Intel Quad Q6600, 4GB DDR2, nVidia 8800m GTX, 3x-Seagate 500GB, WUXGA, Vista Premium-x64 – Production Premium Suite CS4
    Mike Gondek replied 16 years, 9 months ago 2 Members · 1 Reply
  • Mike Gondek
    December 28, 2009 at 4:44 pm
    Try resetting your Photoshop Prefs.
    If that does not work, you may need to completely uninstall your Adobe Suite(especially Acrobat & Photpshop) and reinstall.
