Activity Forums Adobe Premiere Pro Only one angle showing in multi-cam editing mode.
  • Only one angle showing in multi-cam editing mode.
    Posted by Mark Norgate on January 13, 2016 at 1:51 pm
    I searched and found similar issues but none that addressed this specifically. Am I missing something here? I’ve:
    – manually synced up some clips in a timeline
    – nested them as a sequence
    – enabled multi-cam on the nested clip
    – a multicam sequence is created, and shows in source monitor with the two angles
    – click multicam edit mode in the timeline and only one angle shows
    What am I doing wrong? I’m 87.5% certain it’s worked fine this way before. Screengrab: https://i.imgur.com/Yd72MRx.jpg
    View post on imgur.com
    Mark Norgate replied 10 years, 8 months ago 2 Members · 4 Replies
  • Herb Sevush
    January 13, 2016 at 3:24 pm
    You have to enable the “multicam viewer” – Shift+Zero.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
  • Mark Norgate
    January 13, 2016 at 4:14 pm
    I’ve done that, you can see multicam view is selected in the screenshot. I would expect to see my two angles on the left screen which is just black, no?
  • Herb Sevush
    January 13, 2016 at 4:36 pm
    [Mark Norgate] “I’ve done that, you can see multicam view is selected in the screenshot. I would expect to see my two angles on the left screen which is just black, no?”
    My apologies for not looking at the screen grab.
    The problem is you have to target the track that you want multicam playback from. Ppro will only play back from the lowest targeted track. In your case you have track 3 targeted but your shots are on tracks 1 and 2. Note that Ppro will only show multicam, and let you switch cameras, on one track at a time, and it is always the lowest targeted track. If no tracks are targeted it will default to track 1.
    Herb Sevush
    Zebra Productions
  • Mark Norgate
    January 13, 2016 at 4:42 pm
    Ahh i didn’t know that! Many thanks for replying.
