Activity Forums Adobe Premiere Pro Only black screen in sequence
  • Only black screen in sequence
    Posted by Sergoke on November 23, 2006 at 8:11 am
    Hi, i’m very new to Adobe Premiere, so sorry in advance if this question is maybe to obvious.
    When using an AVI file in Premiere, it seems all okay, but as soon as you bring it in the timeline, the ‘sequence01’ only seems to give me a black screen, but with sound! What is going on, here? Sometimes is the playback from the sequence somewhat like distorted snow/greenish. I tried already many diffrent ‘options’ but none of them gives a good result. Although, in the forst monitorscreen, does it playback the movie, it is only in the timeline, or controlescreen for the sequence. Please, help me…
    Eddie Lotter replied 17 years, 11 months ago 6 Members · 13 Replies
  • 13 Replies
  • Vince Becquiot
    November 23, 2006 at 6:46 pm
    What version of Premiere and what type of AVI ?
    Vince
  • Sergoke
    November 23, 2006 at 9:15 pm
    Version Premiere 1, and codec is Xvid
    Will i have the same problems in Premiere 2? (’cause you’re asking) 🙂
  • Flipcharmer
    November 24, 2006 at 4:09 am
    I have the same problem, do I need to re-encode the .avi file using a different codec?
  • Vince Becquiot
    November 24, 2006 at 5:28 am
    Well, I did use a couple of Xvid videos in Premiere 2 recently without issue (which did surprise me…)
    Premiere really isn’t meant to support it natively, so if it does, you’re in luck. I would Google Xvid to AVI converter and see what you can find, sorry that’s all the advice I can give you.
    Vince
  • Mike Velte
    November 24, 2006 at 12:15 pm
    Premiere Elements 3 can play most any video that will play in Windows Media Player.
  • Luara Batista
    September 23, 2008 at 9:50 pm
    Hi, I’m sorry.. I didn’t get it
    I’m having the same problem when I import an .avi file… I see a black screen in Sequence…
    What should I do ?
    I’m using Adobe premiere Pro v1.5
    thx
    Luara, from Brazil!
    Hi! 🙂
  • Eddie Lotter
    September 23, 2008 at 10:54 pm
    What codec is used in your AVI file?
    Cheers
    Eddie
  • Luara Batista
    September 23, 2008 at 11:17 pm
    well, I’m really sorry, but I have no idea!
    How can I know that?
    I downloaded a thing that tells me all codecs I’ve installed in my computer… but that’s it…
    Luara, from Brazil!
    Hi! 🙂
  • Eddie Lotter
    September 24, 2008 at 1:15 pm
    In the link I provided there are links to GSpot (among others) that will look inside you AVI file and tell you what codecs are used.
    Cheers
    Eddie
  • Luara Batista
    September 24, 2008 at 9:10 pm
    ok, I downloaded GSpot, and here it is:
    Codec: CVID(_RGB) Name: BI_RGB Raw Bitmap
    and also says: No codec required….
    Luara, from Brazil!
    Hi! 🙂
