Activity › Forums › VEGAS Pro › Only a certain segment is jumpy when I render top field first
  • Only a certain segment is jumpy when I render top field first
    Posted by Ethan Nunn on September 29, 2019 at 5:44 pm
    I’m editing some commercials from a VHS transfer. The recording is 720×480 29.97i Top Field First.
    Here’s the mediainfo on the recording:
    General
    Complete name : D:\virtualdub\Tape Transfers\techtv tape #1.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    Format profile : OpenDML
    File size : 196 GiB
    Duration : 6 h 14 min
    Overall bit rate : 75.0 Mb/s
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High 4:4:4 Predictive@L3
    Format settings : 1 Ref Frames
    Format settings, CABAC : No
    Format settings, Reference frames : 1 frame
    Codec ID : H264
    Bit rate : 73.4 Mb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 3:2
    Frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : MBAFF
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 7.090
    Stream size : 192 GiB (98%)
    Writing library : x264 core 152 r2851bm ba24899
    Encoding settings : cabac=0 / ref=1 / deblock=0:0:0 / analyse=0:0 / me=dia / subme=0 / psy=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=7 / lookahead_threads=7 / sliced_threads=1 / slices=7 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=0 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=0
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : 1
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 4.02 GiB (2%)
    Alignment : Aligned on interleaves
    Interleave, duration : 50 ms (1.50 video frames)
    Interleave, preload duration : 49 ms
    I’m editing a 720×480 29.97i TFF Vegas project and rendering at 720×480 29.97i TFF so I can do some deinterlacing in AviSynth. However, thsi one segment is always jumpy. For some reason, and I don’t know why this happens, but it seems like the segment is actually BFF even though the entire video is encoded in TFF. Whats the deal? I’ve forced TFF in the project. Is there any way to fix it without rendering the entire video again in BFF (which makes everything else jumpy)?
    I did an ffmpeg encode for uploading the entire tape to archive.org and it seems to throw it off too. It’s always that one ID for some reason. Looks like the original recording does it too. Hmm.
    Here’s a video of my issue.
    https://www.youtube.com/watch?v=OsUVjtNkUz8
    Ethan Nunn replied 6 years, 12 months ago 2 Members · 2 Replies
  • Graham Bernard
    September 30, 2019 at 4:51 am
    [Ethan Nunn] “For some reason, and I don’t know why this happens, but it seems like the segment is actually BFF even though the entire video is encoded in TFF. Whats the deal?”
    Hi Ethan! This may assist: Right click on Event > Properties > Video Event Tab > and then select “Disable Resample” . And the Deal, I’m guessing, is VegasPro being very helpful.
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Ethan Nunn
    September 30, 2019 at 2:37 pm
    Hi Graham!
    I always have resample disabled so that doesn’t work.
