Activity Forums Maxon Cinema 4D Only 500 of 1200 frames render… do you know why?
  • Only 500 of 1200 frames render… do you know why?
    Posted by Matthew Cooper on December 1, 2009 at 8:11 pm
    Hi Folks,
    In my render settings I’ve got it set to render a 1200 frame sequence. This is to TGA’s for taking into AE.
    However, when I set to render it show’s it will only render 500 of the 1200 frames. I changed the settings to all from current etc and nothing. I’ve tinkered around and checked the forums but I can’t see anything relevant.
    So folks, can you point me to the answer and force a very loud “D’oh!” from the UK?
    Best,
    Matt
    http://www.pixelchili.com
    UK Videography and Animation Studio
    Matthew Cooper replied 16 years, 9 months ago 2 Members · 2 Replies
  • Randy Johnson
    December 2, 2009 at 7:48 am
    You need to see that the to and from fields are showing the right amount of frames. Try changing that to Manual then to and from being 1-1200 or what ever you want.
    /randy
  • Matthew Cooper
    December 2, 2009 at 9:57 am
    The solution was to set the frame rate to 60fps. Not sure why this would need altering as it was an image sequence render. Anyway, all fixed. Thanks for you suggestion.
    Matt
