Activity › Forums › Adobe Premiere Pro › Only 30 seconds of audio showing in imported H264 files
  • Only 30 seconds of audio showing in imported H264 files
    Posted by Michael Dean on August 15, 2011 at 11:15 am
    Hi!
    I’m having an odd issue in Premiere when importing h264 files, only the first 30 seconds of audio are showing/playing. There is audio through the whole files (they play with audio all the way through in WMP). Below is a link to a screenshot. I am not having this issue with non-h264 video files.
    https://www.freedomfeens.com/AUDIO/H264-issue.jpg
    Thank you!
    Michael
    Michael Dean replied 15 years, 1 month ago 2 Members · 3 Replies
  • Vince Becquiot
    August 15, 2011 at 4:00 pm
    Hi Michael,
    This is likely caused by the way it was encoded. Is that from a camera, or something that encoded for the web?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Michael Dean
    August 15, 2011 at 5:57 pm
    Neither. They are h264 files I output from Premiere, from a 720p project that has XDCAM footage (with MainConcept’s plugin on my system), h264 footage from a Cannon Vixia, some mini-DV footage, as well as TIFFs, JPGs, WAVs and MP3s.
    The three files I’m showing in that timeline are all two-pass good looking 1280 x 720, 59.94 FPS files. The audio is in them, if I play them in Windows Media Player I can hear the audio all the way through, but no matter how I import them back into Premiere, I can only see and hear the first 30 seconds of audio on each one, and anything I output from them in any format the first 30 seconds of audio on each one. I do not have that problem with other file types, and everything else in premiere seems to be working. For instance, I can output DVD files and author a DVD in Encore and the audio is fine.
    I’m buffaloed by this issue.
    Thank you!
    Michael
  • Michael Dean
    August 16, 2011 at 6:19 am
    I solved the issue. It was an audio codec thing. I’d output as AAC. When I tried it again as AAC2 and re-imported, it worked fine.
    MWD
