Only 2 track audio required from IoHD
I’ve got a studio seesion coming up where I’ll be using an IoHD with MBP to capture uncompressed 10 bit SD for subsequent bluescreen.
I’ve tested and all is okay bit 8 track audio is overkill for this job. As we’ll be a bit pushed on disk space (eSata/express card raid) I would like to reduce the number of audio tracks to two.
I can’t see a way of doing this via FCS’s video/audio settings or editing one of the easy setups. There must be a way of doing this?
Thanks Alan
