Activity Forums Avid Media Composer Only 1 audio track recognized on XDCAM Professional Disc
  • Only 1 audio track recognized on XDCAM Professional Disc
    Posted by Roman Stricker on January 8, 2013 at 11:52 pm
    I have a timeline with 8 tracks of audio and I use “export to device” to burn it onto a 23GB XDCAM professional disc in a Sony PDW-U1 deck.
    After export is completed successfully I use link to AMA to check the MXF file I wrote to the disc. What happens then is, AVID shows me a master clip with only 1 audio track where there are supposed to be eight. I can see that there is only A1 present in the bin, in the timeline and I can hear it over my audio monitors.
    But: There are 8 audio tracks in the PROAV folder on the disc and linking to the master clip on another system works just as it should: all 8 tracks of audio are displayed and played back.
    My initial machine is a quad core Mac Pro early 2009, the reference machine is a MacBook Pro 17″ Mid 2010. I have OSX 10.8.2 and Avid MC 6.0.3 running on both machines.
    The project is SD, 50i, I used MPEG50 for export. I have made mixdowns of all video and audio tracks. On the Mac Pro I unsuccessfully tried the same procedure in different projects with sequences other than the first one.
    And most suprisingly: this workflow had worked just fine for over a year. I even could successfully export and connect again to (via link to AMA) other timelines from the same project only 30 minutes before all of this came up. All over a sudden with absolutely no change to the system at all this bug appeared.
    No, I did not consolidate the media, but doing the mix down should have caused the same effect.
    So all of this leaves me without a feasible way to check the material I have exported to disc.
    Does anyone have a clue what might be a solution?
    Roman Stricker replied 13 years, 8 months ago 2 Members · 2 Replies
  • Job Ter burg
    January 9, 2013 at 7:48 am
    You need to install Sony’s XDCAM drivers. You should not be seeing a PROAV and GENERAL folder, but rather a whole bunch of folders.
    Without that proper driver, you won’t be able to correctly see/open/import the contents of the (virtual) XDCAM disc.
    See https://forums.creativecow.net/thread/142/873704
  • Roman Stricker
    January 9, 2013 at 5:40 pm
    Thanks Job, for your really quick reply!
    Yes, seeing the PROAV folder made me suspicious as well. I must say that working with XDCAM is not my daily bread and when I had to deal with it for the last time about a year ago seeing just the typical Mac volume icon instead of a Sony professional disc icon on your desktop was a clear indicator for a missing XDCAM driver. In that case you would see the PROAV folder but no Clip folder, no Subclip folder and so on.
    But in my case I in fact did see the professional disc icon on the desktop as well as the clip folder, the PROAV folder was just there in addition. So I thought okay, something new, what ever…
    So I guess I do have the XDCAM driver installed. XDCAM Drive utility claims version 3.4.0 to be onboard.
    Also strange: If I use the regular import procedure on the same clip I do get eight tracks of audio and everything is fine. It just happens when using Link to AMA that I am presented with only track A1…
    Got any clue?!?
