Activity Forums Apple Final Cut Pro Legacy onlining with offset
  • onlining with offset
    Posted by Jason W. miltt on September 3, 2005 at 5:09 am
    hi:
    i have and offline edit done but when i online it and reconnect to my online reels there is a 9 second offset. is there any way to change this offset so that i dont have to reedit all the cuts?
    thank you.
    Jason W. miltt replied 21 years ago 2 Members · 5 Replies
  • Jason W. miltt
    September 5, 2005 at 7:45 am
    any ideas?
  • Andy Mees
    September 5, 2005 at 1:48 pm
    exactly 9 seconds? across all reels? … how many reels? are we talking DV, Digibeta or … ??
    possible ideas:
    you could dub your source tapes with new t/c minus the offest, then recapture from them.
    you could export your sequence as an edl or xml, then edit with a suitable text editor to fix the the offset.
    you got any idea how the offset got in there ?
    cheers
    Andy
  • Andy Mees
    September 5, 2005 at 3:08 pm
    another thought
    how about selecting each affected clip and going to Modify > Timecode…
    in the Modify Timecode window change “Frame to Set” to “First”
    check the Source TC checkbox
    change the Timecode value to the corrected value
    repeat for each clip.
    BUT be warned … this is a destructive process, you can’t Undo (although you can repeat the process changing back your ‘corrections’)
    cheers
    Andy
  • Jason W. miltt
    September 5, 2005 at 4:09 pm
    i will try that and come back.
  • Jason W. miltt
    September 6, 2005 at 6:02 am
    i tried but my timeline is still showing the same results. if i press f the frame loaded shows that the timecode has changed in the master clip but the timeline doesnt update. i tried reconnecting but i always get the same results.
    i would like to change to timecode in the master reel and then see the timeline change according to my changes.
    btw, i used this
    https://chxo.com/scripts/pTCcalc.php?tc1
