Activity Forums Adobe After Effects Online Video and Nasdaq effect?
  • Nate Vander plas
    December 20, 2006 at 8:36 pm
    Do you want your video to replace what they have on the Nasdaq sign in the photo or just create the whole thing from scratch? Either way in After Effects you can use tools like distortion and liquify to make your video/images/whatever bend as if it were on a 3D curved sign. If you move your camera or rotate the image, however, this 3D illusion won’t work.
  • Chris Lupetti
    December 20, 2006 at 8:42 pm
    Thanks. I want to make the video from scratch.
    I appreciate the help.
    Best,
    Chris
  • Nate Vander plas
    December 20, 2006 at 9:13 pm
    Is that all you needed to know? If you need more help just ask.
    Nate
  • Steve Roberts
    December 20, 2006 at 11:44 pm
    You might be able to use the CC Cylinder effect within AE, but matching the perspective of the shot might be a pain. I found it easier to do in Lightwave.
    … and if the camera moves in the shot, you’ll need a 3D tracker such as Syntheyes to line things up properly. You’d still have to use a 3D app in that case.
  • Chris Lupetti
    December 22, 2006 at 2:54 pm
    Thanks Steve.
