Activity Forums Avid Media Composer OnLine for AVID Project
  • OnLine for AVID Project
    Posted by Sascha Engel on May 15, 2011 at 5:11 pm
    Hallo,
    I have to OnLine a project (Color Corrections, Titles and so on) for a TV program, that was created on AVIV 5. I will finalize the project in Apple Color and with After Effects. Since I do not have Automatic Duck, the Offline editor has to render out his edited version, so I can work on it. The original material was shot on Sony EX1. He did the editing in the original Sony Codec. What is the best Quicktime Codec Setting, he should export it in, so I can continue in AE & Color?
    Thanx a lot,
    Greetings,
    Sascha
    Sascha Engel replied 15 years ago 3 Members · 6 Replies
  • Sascha Engel
    May 15, 2011 at 5:12 pm
    P.S.: Is there no way, you can export an XML File from AVID, so I can open it in FCP?
    Sascha
  • Glen Montgomery
    May 15, 2011 at 5:33 pm
    Don’t have any answers for you but a potential lead. Check out Shane Ross’ blog at https://lfhd.net/
    He deals with avid>fcp>color stuff a lot and does great write ups on this type of workflow. Personally I would have the editor at least transcode the sequence to DNxHD 175X so you have 10 bit files to push around in color. Good luck.
    Editor / Motion Graphics Artist
    http://www.GlenMontgomeryIII.com
  • Shane Ross
    May 16, 2011 at 8:28 am
    [Sascha Engel] “P.S.: Is there no way, you can export an XML File from AVID, so I can open it in FCP?”
    Avid does not do XML. AAF, OMF…no XML. If you want the sequence and to link to the original media, you NEED Automatic Duck. There is a Boris plugin that is cheaper, but it isn’t as robust. The DUck works and works well.
    [Sascha Engel] “Since I do not have Automatic Duck, the Offline editor has to render out his edited version, so I can work on it. The original material was shot on Sony EX1. He did the editing in the original Sony Codec. What is the best Quicktime Codec Setting, he should export it in, so I can continue in AE & Color?”
    They accessed the footage via AMA? Didn’t transcode? Well…that might put a wrinkle into things. There are many issues here. Mainly that Color only accepts a few codecs…ProRes, DVCPRO HD, HDV, XDCAM from FCP (not sure how it would deal with the format exported from Avid), R3D, DV.
    If I were you, I’d have the offline editor export a small 2 min chunk of video for you to test and play with…see if you can get things to work. What you might end up doing is taking the file he gives you, and transcoding it to ProRes. And if it is one loooooong file, you might have to chop it up in FCP, so that you have separate shots. Or see if you can also get an EDL from the Avid and have color chop it up.
    This is slightly more difficult without the Duck…but doable.
    Shane
  • Sascha Engel
    May 16, 2011 at 6:41 pm
    Thanx for everybody’s advice!!!!
    Basically it comes down to saving up the money, to buy one day the Holy Automatic Duck!
    Until then I will do it the old fashioned way of getting OffLine as rendered File!
    Start saving now 😉
    Sascha
  • Shane Ross
    May 16, 2011 at 6:56 pm
    That “offline” file will be full resolution though, right?
    Shane
  • Sascha Engel
    May 16, 2011 at 7:41 pm
    Yes, in QT Animation & DNX Codec.
