Activity › Forums › Avid Media Composer › online edtiing with Avid Xpress Pro
  • online edtiing with Avid Xpress Pro
    Posted by Dan O’brien on May 14, 2005 at 3:56 pm
    The company I work for is trying to make our 2 Xpress Pro bays online digibeta bays. Is it possible to do online 1:1 editing from digibeta with Avid Xpress Pro? Would I need an SDI Mojo? What are the minimum system requirements for the PC? And would I need Avid drives or Unity? Or would it be a lot simpler to get an adrenaline?
    Any information would be greatly appreciated.
    Dan O’Brien
    Grinner Hester replied 21 years, 4 months ago 3 Members · 2 Replies
  • Michael Phillips
    May 14, 2005 at 5:33 pm
    Xpress Pro and Mojo cannot capture SDI but can do uncompressed analog component. This may make your decision right away. Adrenaline can capture SDI with embedded audio or AES/EBU digital audio. The captured media can be moved to Xpress Pro with Mojo if desired for increased flexibility in the workflow.
    Michael
  • Grinner Hester
    May 15, 2005 at 5:50 am
    Adrenaline (or a used meridien-based MC) would be best for what you’ve described.
    Getting technical, digibeta is 2:1 so, no you can’t really do 1:1 with it but you can do it as uncompressed as any linear bay could.
    Not trying to confuse the issue there. Based on how ya asked it though… no.
