Activity › Forums › Panasonic Cameras › online dvcpro50 vs dv clips
Posted by Rob Katz on December 18, 2005 at 7:59 pmone of the reasons i’m interested in the hvx200 is it will give me access to dvcpro50.
i have been told that is a MUCH better format than dv.
i was wondering if u good folks know of any online links where i can “see” a comparison of dvcpro50 vs dvcpro25?
thanks in advance
be well
rob katz
harvest film companyToke replied 20 years, 9 months ago 6 Members · 10 Replies -
Donatello
December 18, 2005 at 9:33 pmDV has 4:1:1 color space .. DVCpro 50 has 4:2:2 color space ( 2x ) ..
but it all comes down to the project .. your dv image will improve if you use a camera with 2/3″ CCD’s .. chroma keying, rotoscoping i smuch easier working in 4:2:2 color space … DVCpro50 isn’t the only 4:2:2 format …look at photo’s at link – DVCpro is probably between digibeta and digital S … dsr 130 is either 1/2 or 2/3 chip ?
https://www.pixelmonger.com/hotgear.html -
Noah Kadner
December 18, 2005 at 10:13 pmDefinitely a way better format the DV- you get the increased color fidelity as well as half the amount of Compression per frame. For my money DVCPRO50 is the ideal mixture of quality vs. cost vs. file size. It’s the best standard definition can be and not be shooting uncompressed nor be super expensive Digibeta.
Noah
Toke
December 18, 2005 at 11:31 pmIt’s not half the compression.
Dv (4:2:0 or 4:1:1) has 12b/px, so datarate is 124Mbps and with 25Mbps it has compression rate of 5:1.
Dvcpro (4:2:2) has 16b/px, so datarate is 166Mbps and with 50Mbps it has compression rate of 3.3:1.
So dvcpro has 33% lighter compression than dv. -
Rob Katz
December 19, 2005 at 2:21 amso folks, i understand the math as to why dvcpro50 is better but can anyone point me to some links that do a side-by-side comparison of the 50mbps and the 25mbps footage so i can “see” the difference?
as always, thanks in advance for sharing
be well
rob katz
harvest film -
Barry Green
December 19, 2005 at 6:21 amTry Eleventy’s comparison here:
https://www.eleventy.org/dv-en/—————–
Get the most from your DVX camera. The DVX Book and DVX DVD are now available at https://www.dvxuser.com/articles/dvxbook/ and at Amazon (https://www.fiftv.com/db) -
Toke
December 19, 2005 at 6:37 amSorry about that, if I’m picking too much.
I’ve beed sick and in bed for 2 days so I’ve had too much time for surfing around…
I just thought those numbers might clarify the situation to somebody. -
Graeme Nattress
December 19, 2005 at 12:48 pmColour Space is something like REC601 or 709, ie the gamut of displayable colours. Chroma sampling is denoted by the 4:2:2 etc. notation and tells you what the resolution of the chroma components is compared to the resolution of the luma. Two different things. And DV50 is quite nice indeed for an SD format…. If you look at example of Noah’s movie on the Panasonic demo disc, it’s fantastic.
Graeme
– http://www.nattress.com – Film Effects and Standards Conversion for FCP
Rob Katz
December 19, 2005 at 9:59 pmbarry-
that site demonstarted a pretty obvious difference between dvcpro50 and dvcpro25.
i imagine u and others with more experience than i would immediately “see” the difference between dvcpro25 and dvcpro50 in a piece of footage
i wonder if i would “see” that difference at 30fps rather than a static still image?.
any sites with a moving footage comparison?
as always, thank u again and gain for sharing your expereinces
be well
rob katz
harvest film company -
Toke
December 20, 2005 at 12:08 amWith natural footage and progressive frames, I’d say that difference between 4:2:0 and 4:2:2 is very small.
With chroma keying and graphics (without anti-aliasing = ugly) etc. there is a difference.
With interlaced picture (which should have been history by now) 4:2:2 was much needed, because each field needed its separate picture.
