Activity Forums DVD Authoring one video,multiple audio authoring
  • one video,multiple audio authoring
    Posted by Ric Shellhammer on May 9, 2007 at 2:29 pm
    We’ll soon be working on a project that consists of one hour long video track and 5-6 music tracks allowing the user via the menu, to choose the music of choice behind the video. The dvd will be authored in DVD-SP4. Any suggestions on the simplest way to author this project? Do I use languages? Stories?
    ric
    Eric Pautsch replied 19 years, 3 months ago 2 Members · 3 Replies
  • Eric Pautsch
    May 9, 2007 at 4:10 pm
    Lay down your video. Lay down your audio tracks. You can create a menu to choose which audio track you want played and set that up in the button inspector. Not really sure how you want the disc to function.
  • Ric Shellhammer
    May 9, 2007 at 4:20 pm
    Thanks for the info. First play will go directly to a menu with the choices. Assume all the audio tracks have to be exactly the same length as video … right? Is there a limit to audio tracks that can be assigned to the same video track? I couldn’t find that info in the manual.
    ric
  • Eric Pautsch
    May 9, 2007 at 6:14 pm
    Yes..8 are allowed by the DVD spec and DVDSP
