Activity Forums Adobe After Effects Expressions One value to a Slider control
  • One value to a Slider control
    Posted by Sanjeev Ramanathan on January 5, 2011 at 7:47 am
    Can anybody help me to link the slider control to the Y value of the position layer.
    I have a series of circles which are placed in a row, and i want to move only on the ‘Y’value, I created a slider in a Null and i want to link to Y value of the position of the circle. How do i do that?
    sanj.
    Dan Ebberts replied 11 years, 3 months ago 5 Members · 11 Replies
  • 11 Replies
  • Dan Ebberts
    January 5, 2011 at 2:23 pm
    If you want to set the y value with the slider, you could do it like this:
    y = thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”);
    [value[0],y]
    If you just want to adjust the y value with the slider, this would work:
    yAdj = thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”);
    value + [0,yAdj]
    Dan
  • Sanjeev Ramanathan
    January 5, 2011 at 6:08 pm
    Thanks Dan will try that.
    sanj.
    January 13, 2011 at 3:27 am
    HiDan,
    Iam using the one where i can adjust the y value
    (yAdj = thisComp.layer(“Null 1”).effect(“Slider Control”)(“Slider”);
    value + [0,yAdj].
    After i linked the circle to the slider, its working fine. But i have one more issue i want to stop the slider at 80 (80 should be the max., even if i slider more than 80 it shouldn’t move). Now, how do i lock the value at 80 so i can move from 0 to 80 only.
    sanj.
  • Dan Ebberts
    January 13, 2011 at 3:32 am
    Something like this should work:
    value + [0,Math.max(yAdj,80)]
    Dan
  • Ben Robinson
    November 17, 2011 at 8:21 am
    I’m sure this is fairly elementary–but I’m almost completely in the dark when it comes to expressions. Is there a way to link the position value (specifically the y value) of one layer to a slider control so that 1 on the slider is the starting y value (in this case -30), then 2, 3, 4…etc. each increase the y value by 55?
    Any help hugely appreciated.
    Cheers
  • Dan Ebberts
    November 17, 2011 at 2:45 pm
    s = effect(“Slider Control”)(“Slider”);
    [value[0],(s-1)*55-30]
    Dan
    edit: oops, I had a typo in there
    Dan
  • Ben Robinson
    November 17, 2011 at 8:34 pm
    Dan, you’re amazing. I realise that was probably pretty basic–but it really helped me out and I often see your name pop up with regular help and advice. Nice one.
    Cheers
    Ben
  • Losits Robert
    January 15, 2014 at 5:59 pm
    Hello, I need some help.
    How can I increase Slider’s Max Value over 1000000?
    Thanks for your help! 🙂
  • Dan Ebberts
    January 15, 2014 at 6:16 pm
    I don’t believe there’s any way to do that. There may be workarounds though, depending on what you’re trying to do.
    Dan
  • Francisco Rodriguez
    May 29, 2015 at 12:27 am
    Hi dan,
    if this expression works with the Y value
    value + [0,yAdj]
    What is the expression for x value?
    thanks!
