Activity Forums Adobe After Effects Expressions One text layer to change text in multiple layer
  • One text layer to change text in multiple layer
    Posted by Fahd Chishty on January 6, 2015 at 5:45 pm
    I had been looking for some expression that would allow me to change multiple text layers while I (or any other user) would need to change only 1 layer.
    To explain my point, I had a composition in which there were 5 words in 5 different layers with different animations. In order to change a word, I had to look up all its layers and change them. I wanted 1 text layer, which would act as a source and all the word layer would take its source text.
    So I made the following expression that you need to put in the word layer, mentioning which word number you want to pick from the source.
    Hope it helps someone else 🙂
    charNum = 2; //The index of word which you want to take
    totChars=12; //Total Number of characters in the sentence (excluding \r)
    totWords=4; //Enter how many words there are in the sentence
    //defining other variables
    cont=true;
    count=0;
    i=0;
    j=0;
    txt=[];
    totChars=totChars+totWords-1;
    myLayer=thisComp.layer("Change Text Here");
    while(cont && i=charNum)
    cont=false;
    break;
    txt[j]=myLayer.text.sourceText[i];
    i++;
    j++;
    txt.join("");
    Fahd Chishty replied 11 years, 8 months ago 1 Member · 1 Reply
  • Fahd Chishty
    January 7, 2015 at 2:35 pm
    The code above needed some enhancements and tweaking for working right.
    I am putting the modified code here for any who might need it 🙂
    charNum = 1; //The index of word which you want to take
    totChars=myLayer.text.sourceText.value.length; //Total Number of characters in the sentence (excluding \r)
    totWords=getWords(myLayer); //Number of words there are in the sentence
    cont=true;
    count=0;
    i=0;
    j=0;
    fJ=0;
    txt=[];
    cont=false;
    break;
    i++;
    j++;
    fJ;
    txt.splice(fJ, (txt.length-fJ));
    txt.join("");
    function getWords(layer)
    x=0;
    y=0;
    while (x<totChars)
    if (layer.text.sourceText[x]=="\r")
    {y++;}
    x++;
    return y+1;
