Activity Forums Adobe Premiere Pro One project into multiple projects
  • One project into multiple projects
    Posted by Michael Tesh on August 7, 2018 at 4:15 am
    I don’t know if you could always open multiple projects in Premiere at the same time or if this is a recent addition, but I just found out about it and have been using it and it’s great. That said, I have a couple older clients where all of their video projects exist in one (for each client) massive Premiere project file. I had simply created one Premiere project and inside of that, a folder of each video (sub) project I did for them.
    Is there an easy way to split each of these (sub project) folders into their own project files or is it just a matter of duplicating this one project file multiple times and then opening each up and deleting all but one (sub project) folder from each?
    Michael Tesh replied 8 years, 1 month ago 2 Members · 2 Replies
  • Jamie Pickell
    August 7, 2018 at 4:33 pm
    Yes, you can export folders or sequences as their own Premiere Pro project files. Select the folder or sequence that you want to be its own project and then go File > Export > Selection as Premiere Project and a Save As window will open.
    Jamie
  • Michael Tesh
    August 9, 2018 at 3:03 pm
    Thank you so much. That helps a lot.
