Activity Forums Maxon Cinema 4D one object move base on other surface.
  • one object move base on other surface.
    Posted by Luis Florez on September 16, 2017 at 4:35 am
    hi how are you?
    i am creating a simulation of an engine valve working. I have kind achieved what I want to do.
    i want the valve to move by the surface of the object that is touching it, (It has a not circular rotation.)( more like and oval rotation).
    I have achieved my goal just partially. whenever the objet farthest position is reached, the valve gets to where i want. the same with the lowest position.
    anything in between makes the valve to move away from the object.
    I ussed expresso to achive it.
    here some pic to clarify my issue.
    here a video of what I want to achive
    https://www.youtube.com/watch?v=OGj8OneMjek
    Live your life with passion
    Luis Florez replied 9 years ago 2 Members · 2 Replies
  • Brian Jones
    September 16, 2017 at 9:06 pm
    what C4D do you have? With Dynamics (if you have it) you can do this.
    11692_camvalvetrial.c4d.zip
  • Luis Florez
    September 18, 2017 at 5:08 pm
    thanks.. that do the trick.
    how did you do that? it is perfect.
