Activity › Forums › Adobe After Effects › One node VS two node camera: Best uses
Posted by Tim Boknecht on May 23, 2013 at 9:25 pmUp till now I’ve always used two node cameras in AE. So let me poll you guys:
When do you use a one node camera over two? What are the best uses for each?
Tim Boknecht
Media Producer
Bravo ProductionsMatthew Woods replied 13 years, 3 months ago 4 Members · 4 Replies -
Roland R. kahlenberg
May 23, 2013 at 10:14 pmTwo-nodes when I need/want to be more expressive with the camera. Then again, it’s a case of different strokes for different folks – so keep this in mind.
Cheers
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE -
Jason Jantzen
May 24, 2013 at 4:27 pmIf I’m thinking correctly, one node uses rotation/orientation only and no POI, right? In that case, you could use a one node camera like most people use camera parented to null for planar motion only.
Jason Jantzen
vimeo.com/jasonj -
Tim Boknecht
May 24, 2013 at 6:29 pmI’ve been setting keyframes for position and point of interest (keyboard shortcut A), then using the camera tools (C) to automatically create keyframes down the timeline.
Dave, could you upload a down-and-dirty example of this 2 null rig set up in a CS5 or earlier project?
Tim Boknecht
Media Producer
Bravo Productions -
Matthew Woods
May 24, 2013 at 8:48 pmInteresting. I always use a one node camera when I want to imitate a tripod. Then the rotation controls work pretty much the same (although the gimbal may be different from a tripod) I also use a one node camera when I am doing planar moves where I don’t want the camera to rotate.
I always use a two node camera for complex moves where I want the camera’s position and orientation to animate independently. Especially when using 3d objects or element 3d. For example, if you want to move the camera around while always looking at one object in the scene, copy the position of the object to the point of interest of the camera. It gives a nice jib/crane like look. (Though much more powerful) You can animate the camera orientation from aiming at one object to another by copying their position to the point of interest. Often I will end up tweaking the exact poi, but copying positions is a good start. In order to make it smooth though, you usually have to go into 4 views and smooth out the bezier curves of the motion paths for both the camera, and the anchor point. If you want to track a moving object, pickwhip link the camera’s poi to the position of the object with an expression.
Hope that helps get started.
Point of interest can be really powerful if you learn how to use it well.
Need a quick break from motion graphics?
Try my game Constellation at:
https://www.paperdragongames.com
