Activity › Forums › Adobe Premiere Pro › One Multicam Sequence is out of Sync
  • One Multicam Sequence is out of Sync
    Posted by Allec Roach on July 1, 2016 at 9:05 pm
    I am trying to create a multicam sequence with three different sources. They are different sizes, but I don’t think that should be an issue. The problem is that one source is not in sync. I have tried using in points and also using a marker to sync the videos. The marker seemed to work better syncing the first two, but the last source is about 2 minutes off. I’m not sure what the problem is and I need help! Also, the one video that isn’t syncing is approximately 6 minutes longer than the other ones. Let me know if you need any more info. This is my first post and I haven’t gotten the hang of this yet, so be gentle!
    Jay Whittle replied 8 years, 2 months ago 3 Members · 4 Replies
  • Andrew Kimery
    July 2, 2016 at 4:26 am
    Flippy,
    Have you tried using the built in sync-by-waveform in PPro?
    [Dave LaRonde] “This sounds like you have a frame rate mismatch among the cameras. All the frame rates have to match. I’d double-check those frame rates…. and you might want to reshoot once you learn the bad news.
    PPro will sync mismatched frame rates w/o a hitch.
  • Allec Roach
    July 3, 2016 at 2:12 am
    Can you clarify on this “sync-by-waveform” thing? I’ve never heard of it before. Thanks!
  • Allec Roach
    July 3, 2016 at 2:34 am
    Okay, I’ve figured it out! On the out of sync source, it was actually being recorded in slow-motion, but it wasn’t enough to be noticeable. That caused it to be synced at the sync point but get farther off as the video went along, I sped just the video up to be the same duration as the audio track and we are golden! Thanks for the responses!
  • Jay Whittle
    June 29, 2018 at 1:44 pm
    If some footage is shot in drop frame and non drop frame, will this create sync problems ?
    I know the answer is problem yes, but I want my producer to hear it from a pro so they can
    fix in future shoots.
