Activity › Forums › Maxon Cinema 4D › one more thinking particles question
  • one more thinking particles question
    Posted by Bender on January 12, 2006 at 8:03 pm
    hi guys!
    ok…here we go:
    what i wanna do is pretty simple (i guess so)
    i wanna have small cubes coming out a small tp emitter grow a bit and disappear slighly! i’m pretty new to c4d and i cant figure out how to adjust speed, visibility and all that stuff!
    thanks very much!
    florian
    Brian Jones replied 20 years, 8 months ago 2 Members · 1 Reply
  • Brian Jones
    January 15, 2006 at 5:13 pm
    The simple way-
    animate the properties you want in the box that will be emitted, each box’s animation starts a soon as it is born as a particle. Easy and/but all particles behave the same which may or may not be what you want.
    or
    use the settings in the particle generating node (a PStorm node if you used the ‘TP Basic Emitter’ to start) to change size. Be warned though TP has a LOT of power which means there is almost always more than one way to get what you want and the only way to know what is possible is to have an understanding (at least basic) of all the TP nodes and the XPresso nodes. You can do stuff without knowing much about TP but you can do a lot more if you dig around and practice/play.
