Activity › Forums › Apple Final Cut Pro Legacy › one more: dvd recorders?
  • one more: dvd recorders?
    Posted by Cade Muhlig on May 24, 2007 at 9:09 pm
    i am about to buy a dvd recorder to give me the ability to record straight to a dvd from the timeline (using kona), any recommendations?
    one with a hard drive i assume would be very useful.
    Walter Biscardi replied 19 years, 4 months ago 6 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    May 24, 2007 at 10:22 pm
    I picked up a Panasonic DVD recorder at BestBuy for this very purpose. No hard drive, just put in a disc, hit play on your timeline and record on the machine. Very easy.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • David Roth weiss
    May 25, 2007 at 12:14 am
    Walter,
    How do you have it wired? What inputs?
    THNX,
    David
  • Michael Lynch
    May 25, 2007 at 12:16 am
    I do the same as Walter. Only drawbacks are recording in real time, so a 30 minute program takes 30 minutes, which is 30 minutes you can’t be editing something else. The other is the menu. No fancy menus on these recorders, thus I mostly use it as a quick way to burn rough edits for review by the client. I build the DVD proper in DSP after final approval. Oh, and I’ve had a few instances where the burned discs wouldn’t play in the clients machine, but it seems the newer the playback machine, the better the chance.
    -Mike
    G5 – 2GIG DUAL – 2GIG RAM
    FCP; AE; PS; DSP
  • Michael Lynch
    May 25, 2007 at 12:18 am
    As for wiring on mine I’m coming out via firewire into the front of the deck – it’s got DV in. I can’t capture from it though, it’s only one way. Your card may give you other options.
    -Mike
    FCP; AE; PS; DSP
  • David Roth weiss
    May 25, 2007 at 12:27 am
    [Michael Lynch] “I’m coming out via firewire into the front of the deck”
    Thanks Mike,
    That’s good to know, the ones I tried in the past would not work using firewire out of FCP.
    THNX,
    DRW
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Nate
    May 25, 2007 at 12:58 am
    My JVC DVD recorder with VHS player/recorder, I would not recomend. Yes it is three + years old and was about $225 when purchased. The DVD recorder / player is now dead. It worked great for three years, but no more. I don’t know the life span on other machines, but I am not impressed with three years. I could firewire from the DSR40 or Final Cut Pro. It was great for time code window dubs. Not the prettiest encode, but very usable.
  • Chris Borjis
    May 25, 2007 at 3:19 pm
    [Michael Lynch] “Oh, and I’ve had a few instances where the burned discs wouldn’t play in the clients machine”
    Just an FYI that 99% of the time that can be fixed by simply
    making a copy of the disc. It strips away what ever that extra layer of incompatability is.
    I have always put very high regards to the Panasonic line of DVD Recorders and recommend them to any professional here.
    To this day they have the best picture quality and reliability of operation.
    I have had mine since August 2001 (DMR-E30 model)its got
    over 2,100 hours on the laser diode and I still use it every week.
    Great Machine.
  • Walter Biscardi
    May 25, 2007 at 3:24 pm
    [David Roth Weiss] “Walter,
    How do you have it wired? What inputs?”
    Composite out of the Kona 3, RCA Audio out of the Kona 3, directly into the DVD Recorder.
    I have to switch the cable on the front of the Kona to go from the component feed out to my system to composite.
  • David Roth weiss
    May 25, 2007 at 3:29 pm
    [walter biscardi] “Composite out of the Kona”
    That’s what I’d like to avoid if possible. Firewire would be so cool if they still enable it. I fear the MPAA has forced them to disable firewire capability.
    BTW, my FCS2 just arrived. I’m opening the box now and installing immediately. Oh what fun…
    David
    David Roth Weiss
    Los Angeles
  • Walter Biscardi
    May 25, 2007 at 3:32 pm
    [Michael Lynch] “do the same as Walter. Only drawbacks are recording in real time, so a 30 minute program takes 30 minutes, which is 30 minutes you can’t be editing something else.”
    Which takes a LOT less time than authoring a DVD.
    [Michael Lynch] “The other is the menu. No fancy menus on these recorders, thus I mostly use it as a quick way to burn rough edits for review by the client.”
    Exactly, that’s primarily what we use it for. But again, much faster than authoring a DVD.
    Another use for the unit is Window Burn copies of tapes. We’re doing a project right now where will be burning about 200 tapes to DVD with window burn for a library archive. This is a great way to store the footage and be able to access it without using the original recordings.
    [Michael Lynch] “Oh, and I’ve had a few instances where the burned discs wouldn’t play in the clients machine, but it seems the newer the playback machine, the better the chance.”
    Knock on wood, we have not run into that yet with our original Philips and now the Panasonic DVD recorder.
