Activity › Forums › Adobe Premiere Pro › One hour movie = 15GB
Posted by Howard Mills on March 14, 2007 at 1:29 pmHello everyone, I’m a new PP2 user and was wondering how to get a 1 hour video small enough to fit on a dvd and maintain the high quality?
I find it amazing how movie makers can fit a 90 minute movie on a DVD and maintain the high quality.
Thanks for your help.
Dell XPS 400,
2.80 MHZ,
1 GB Ram,
1-160 GB HD,
Win XP Pro SP2,
Canon XL1,
JVC-BR- DV3000U,Kamrul Hasan replied 19 years, 6 months ago 6 Members · 20 Replies -
Howard Mills
March 14, 2007 at 1:49 pmI’ve tried that. When I choose Export > Export to DVD and choose burn to disk my “BURN” button is grayed out. I have a blank DVD in the drive and my DVD burner is selected. Any ideas?
Dell XPS 400,
2.80 MHZ,
1 GB Ram,
1-160 GB HD,
Win XP Pro SP2,
Canon XL1,
JVC-BR- DV3000U, -
Harm Millaard
March 14, 2007 at 2:12 pmUsing the trial version? That does not support MPEG, you need the full version for that.
Howard Mills
March 14, 2007 at 4:40 pmI’m using the full, licened and activated product.
Dell XPS 400,
2.80 MHZ,
1 GB Ram,
1-160 GB HD,
Win XP Pro SP2,
Canon XL1,
JVC-BR- DV3000U, -
Harm Millaard
March 14, 2007 at 4:57 pmI’m baffled. Both of my burners are recognized and burning is enabled, although I prefer to export to Encore and author from there. You wouldn’t be running XP64 or Vista would you?
Tclark
March 14, 2007 at 5:07 pmIf your DVD burners are grayed out that means you prabably have other burning software like Roxio that took the priority of the drive. Do a search for “Can not burn a dvd” in the adobe forum and you will find how to fix it. I had the same problem and I solved it. I just can not remeber how exactly. It had something to do with upper and lower filters. It is something that can be fixed in windows.
Mike Velte
March 14, 2007 at 6:16 pmAnother option;
Choose the burn to folder option and then use your burning software to do the burning of the VIDEO_TS folder. -
Howard Mills
March 14, 2007 at 6:22 pmNo, I’m running XP Pro SP2
Dell XPS 400,
2.80 MHZ,
1 GB Ram,
1-160 GB HD,
Win XP Pro SP2,
Canon XL1,
JVC-BR- DV3000U, -
Harm Millaard
March 14, 2007 at 6:29 pmThen TClark is probably right. Your configuration is likely confused by having Roxio or similar software installed. Either do a search for the registry fixes or use Mike’s suggestion.
Howard Mills
March 14, 2007 at 6:31 pmTClark, you’re right, I do have Roxio EZ CD and DVD Creator 6 on the system. Here’s the strange thing, I opened a 3.67GB project and exported to DVD. My “BURN” button is now accessible. So I guess there must me a problem with the 15GB clip?
Let’s get back to my original question, how and what do I do to reduce the size of the 15GB clip but also retain quality?
Thanks for all the feedback.
Dell XPS 400,
2.80 MHZ,
1 GB Ram,
1-160 GB HD,
Win XP Pro SP2,
Canon XL1,
JVC-BR- DV3000U,
