Activity Forums Adobe Encore DVD One HD format to another HD format question with CS4
  • One HD format to another HD format question with CS4
    Posted by Clint Milner on October 25, 2011 at 11:41 am
    Hi All,
    I’m doing a project in Encore CS4. It will be a Blu-ray disc, and I will be targeting both the Americas and Europe. I will also be using Blustreak Premaster to convert the BD Image to a BDCMF.
    Bascially the client is suppling the final edit as 1920×1080 25fps interlaced.
    I read on this thread that the best solution would be to have the footage be 1920×1080 24fps progressive.
    I’m using the CS4 Master Suite and I have access to ProCoder 3.
    Would someone be able to ‘nudge’ me in the right direction with regards to converting the video?
    Any help is truely appreicated!
    Kind Regards,
    Clint
    Adobe CS4 Master Suite
    Vista Ultimate 64 SP1
    Intel Core i7 920 @ 3.60GHz
    12 GB DDR3 RAM
    NVidia Quadro FX 3700
    Matrox RT.X2 LE Capture Card
    4 TB RAID 5
    Clint Milner replied 14 years, 10 months ago 2 Members · 2 Replies
  • Daniel Ludwig
    October 25, 2011 at 5:47 pm
    Hi Clint,
    you need to conform your quicktime-movie to 1080p24.
    if you have been working with FCP you could use apple cinematools for this.
    but I guess you are going the adobe-way, so you should use Aftereffects to do so, you can conform 25 to 24.
    that means your video/audio will slow down by 4%, but this is a common workflow for things like that.
    afterwards you need to stretch your audio 4% as well, to fit the lenth of the movie.
    here you´ll find a short guide how you can proceed using FCP and apple cinema tools.
    https://rivergatesoftware.com/tutorial-nonuscontent
    cheers
    danny
  • Clint Milner
    October 26, 2011 at 11:11 am
    Hi Danny,
    Many thanks for the tip. Hopefully I can get this to work using the Adobe route.
    Cheers.
    12 GB DDR3 RAM
    4 TB RAID 5
