Activity Forums Apple Final Cut Pro Legacy One Hard Drive for them ALL!
  • One Hard Drive for them ALL!
    Posted by Richard Ragon on July 22, 2005 at 10:09 pm
    Seams that I create a removable hard drive, and format it with my Mac (OSX Journal) I can’t plug it into my PC because the PC doesn’t recognize it.. And, if I format that drive with NTSF (Windows) I can copy files to the Mac, but I just can’t write files to that drive.
    Any way to format the removable drive so that I can share it with Windows and Mac machines?
    -Richard
    Bryce Whiteside replied 21 years, 2 months ago 4 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    July 22, 2005 at 10:24 pm
    The Mac can read most PC formatted drives. BUT…when it comes to capturing media for FCP…the drives need to be a specific format…Mac OS extended. I’m sorry that you can’t then hook that drive up to a PC. YOu might consider:
    Shane’s Stock Tip #24: Transporting files between Mac & PC
    Get a transport drive. A FW drive that is formatted for both PC and Avid that is used for transporting footage only. A drive you use for transporting files only…not for use as a capture drive. It can be FW, or USB…just as long as it is formatted for both PC and Mac so they can both access it.
    Like a bus powered Porche drive, or FireLite drives:
    https://www.macconnection.com/ProductDetail?Sku=462950
    https://www.macconnection.com/ProductDetail?Sku=456765
    Then you can export a QT movie (self contained, sequence setttings) and take it into AE on the PC to work with.
    Then when he is done on AE…export using the sequence settings…like DV/NTSC…and put on that drive. Bring the drive to your Mac, copy the files off it onto the Capture drive and put it in a separate folder like AE Comps…then import into FCP.
  • Bryce Whiteside
    July 22, 2005 at 10:47 pm
    Mediafour – MacDrive 6 when installed on the PC will enable the PC to read/write HFS+ formatted Macintosh drives.
    FYI,
    Bryce
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Bryce Whiteside
    July 22, 2005 at 10:51 pm
    Don’t journal media drives.
    FYI,
    Bryce
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Richard Ragon
    July 22, 2005 at 11:03 pm
    ” Get a transport drive.” YES!! That’s what I want. A transport drive!
    Unfortunately, no where does it say what “format” this transport drive should be set to!!!
    -Richard
  • Richard Ragon
    July 22, 2005 at 11:06 pm
    I might try this..
    Format it with Unix! I have a shared drive in my desktop mac as a unix drive, and my windows machine seams to have no issues with using it as a network drive. It just sets the permissions for that user only though.
    Anything better?
    -Richard
  • John
    July 26, 2005 at 8:46 pm
    Format the drive on a PC as FAT file system. Then, you should be good to go.
  • Bryce Whiteside
    July 26, 2005 at 8:51 pm
    But you will have a 4GB file size limit.
    Inquiring minds…
    Bryce
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Bryce Whiteside
    July 26, 2005 at 9:16 pm
    Limitations of the FAT32 File System in Windows XP
    And some further light reading:
    Understanding File-Size Limits on NTFS and FAT
    Inquiring minds…
    Bryce
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
