Activity › Forums › Apple Final Cut Pro Legacy › one G5 connect 2 XserveRAID installed with OS 10.3.9
  • one G5 connect 2 XserveRAID installed with OS 10.3.9
    Posted by Kinthy on April 23, 2005 at 2:14 am
    For Capture HD video with uncompress 10bit with decklink card, it drop frame. But the decklink speed test performance is very good.
    Any idea why it drop frame?
    Kinthy replied 21 years, 5 months ago 2 Members · 2 Replies
  • Adam Schmidt
    April 23, 2005 at 5:00 am
    Are the Xserves 14 drive models? And are the two 7 drive sides striped together? Are they 512MB cache raid controllers? Are you running two Dual port Fiber Channel cards to connect the two xserves? Are the cards in the correct slot? Do you have at least 2GB of ram in the G5?
    Lots of questions,
    Adam
  • Kinthy
    April 26, 2005 at 1:38 am
    Yes Both Drive are 14 drives with 400G for each one.
    Yes they are strip togather with raid 0.
    Yes the cache control with maximum cache.
    Yes using the apple dual port cards.
    Yes, the cards are in the correct slots.
    Not sure why it happen, after several test, it should not the RAID problem, maybe the system have somethings corrupted. We re-install the whole system, the problem gone. it maybe the driver problem or system problem.
    thanks for your help.
