Activity › Forums › Adobe After Effects Expressions › One expression to preview Particular?
  • One expression to preview Particular?
    Posted by Greg Neumayer on October 7, 2011 at 6:43 pm
    I’d like to link my motion preview setting of Particular to an expression, so I can toggle the many instances of Particular between preview and full render. Can I do this with an expression? The Render Mode setting allows me to turn on expressions, but I’m not sure how to write/pic-whip it so that I can give it a value from somewhere else, since it’s a pulldown box with two options, “Motion Preview” and “Full Render”. Can I plug in “Motion Preview” from another expression?
    -Greg
    Antifreeze Design
    https://www.antifreezedesign.com
    Dan Ebberts
    replied 14 years, 11 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    October 7, 2011 at 8:10 pm
    You could link the Render Mode parameters to a Checkbox Control with an expressions like this:
    thisComp.layer(“controls”).effect(“Checkbox Control”)(“Checkbox”).value + 1
    When the Checkbox is unchecked, you get Motion Preview, when it’s checked you get Full Render.
    Dan
  • Greg Neumayer
    October 10, 2011 at 6:40 pm
    Thanks Dan. That works perfectly.
    Am I correct in understanding that it works because the Checkbox control is submitting a (non-strict) Boolean as 0 or 1, and the Particular Render Mode pulldown is looking for a value of either 1 or 2? (It seems odd that AE pulldown menus wouldn’t also be zero-based arrays.)
    Antifreeze Design
  • Dan Ebberts
    October 10, 2011 at 6:50 pm
    Yes, that’s correct.
    Dan
