Activity Forums Adobe Premiere Pro one click on the filemen
  • one click on the filemen
    Posted by Patfish on March 10, 2007 at 11:19 pm
    hi everybody!
    i have a great problem, every time i press the “filemenu” button of premiere 2.0, the hole program freez.
    the same happens if i click on the presettings men
    Blast1 replied 19 years, 6 months ago 5 Members · 12 Replies
  • 12 Replies
  • Patfish
    March 11, 2007 at 1:25 am
    i have a little correction!
    the problem wiht the filemen
  • Vince Becquiot
    March 11, 2007 at 5:28 am
    Is it just with one particular project or with any video files ?
    Vince
  • Patfish
    March 11, 2007 at 10:13 am
    the problem is with any video file 🙁
  • Vince Becquiot
    March 11, 2007 at 5:04 pm
    Dump your preferences holding Ctrl+Shift at start up, if that doesn’t work a new install may be required.
    Vince
  • Perry Cheng
    March 11, 2007 at 9:26 pm
    What’s the file extension? Are they DIVX or any MPEG? PPro is not good at handling these files.
    Perry
  • Patfish
    March 11, 2007 at 10:10 pm
    i have the problem with any file format. I
  • Baz Leffler
    March 11, 2007 at 11:04 pm
    Try deleting ‘workingset.prsl’ in mydocuments\adobe\premierepro2\styles\
  • Baz Leffler
    March 11, 2007 at 11:05 pm
  • Blast1
    March 11, 2007 at 11:15 pm
    [Vincent Becquiot] “Ctrl+Shift at start up”
    That for older version of Premiere, for Ppro use:(plug-in cache file is like the preferences file.)
    Quote:
    “2. Re-create the Adobe Premiere Pro PluginCache file.
    Some startup problems are caused by a damaged PluginCache file. To re-create the file, hold down the Shift key while choosing Start > Programs > Adobe Premiere Pro 2.0. Release the key when the Welcome screen appears.”
  • Blast1
    March 11, 2007 at 11:18 pm
    [patfish] “i have the problem with any file format.”
    Here is a list of files that Ppro can use, any other can cause erratic behavior
    https://www.adobe.com/cfusion/knowledgebase/index.cfm?id=329350
