Activity Forums Adobe After Effects Expressions onChanging function doesn’t work on AE CC
  • onChanging function doesn’t work on AE CC
    Posted by Paul Chain on September 26, 2016 at 10:25 pm
    Hello, I’m a little bit confused…
    I’ve just created a script with a sliders using the onChanging function to control the opacity of a selected layer. The problem is that if I run the script in AE cs5 when I drag the slider I can see the opacity change in real time but if I run it on AE CC2015 the onChanging works like the onChange function, so I can see the opacity change only when I release the slider.
    Why?
    Thank you very much for your support.
    Paul Chain replied 9 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
