Activity Forums Panasonic Cameras on-Set HD playback for HVX200
  • on-Set HD playback for HVX200
    Posted by Arthur Luhn on January 8, 2007 at 12:20 am
    What is an ideal HD monitor for on-set playback? I just checked the ones (Panasonic BTLH1700W 17″ Widescreen Flat Panel Monitor HD/SD) that Panasonic offered that goes with the HVX-200 and the price is obviously way out there- question: could I substitute this with any HDTV at, say, Best Buy? If the playback is 720N or 1080i, would this be an issue?
    Thanks..
    Noah Kadner replied 19 years, 8 months ago 2 Members · 1 Reply
  • Noah Kadner
    January 9, 2007 at 2:25 am
    Sure you can but of course it won’t come with a waveform monitor or accurate image controls. But if you just want a simple playback monitor try one of the 17″ Sony LCD’s. Those are around $500 and are not bad. Make sure you get one that has component HD input.
    -Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
