Activity › Forums › Adobe Encore DVD › on importing PAL quicktime into encore…
  • on importing PAL quicktime into encore…
    Posted by Robdelange on November 22, 2005 at 10:26 am
    hi here, a encore newbie here..,
    i made some short clips in Avid Xpress DV and
    exported them as 720×576 quicktime’s, now when
    i try to import them into Encore it say’s that
    they have to be 720×576, but the are !, what goes wrong?
    Robdelange replied 20 years, 10 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    November 22, 2005 at 5:23 pm
    The error message is slightly off, I’ve seen it do this before. Encore sees something wrong, but the only error message it knows to put up is about the frame size. Something else is likely wrong with the file, such as the pixel aspect ratio, bitrate, frame rate, etc.
  • Robdelange
    November 22, 2005 at 9:21 pm
    thanx, i checked the spec’s of the quicktimes again
    and i think i found someting, somewhere in the movie export
    settings i found in the box “motion” an option “frame reordering”
    i’t was turned on by default, i turned it off, and now it seems to
    work !!
