Activity › Forums › Avid Media Composer › On export AMC seems to apply a LUT
  • On export AMC seems to apply a LUT
    Posted by Simon Birman on March 26, 2019 at 3:26 pm
    Hi there,
    I’m working on a project where the assistant couldn’t figure out how to burn in the LUT before exporting the proxies from Resolve. She would add the LUT in AMC using the Source Settings menu.
    When I arrived, I resolved the LUT burn in issue but now I have timelines with both, rushes modified by source settings and rushes with the burnt in LUT.
    On export, it seems as if Avid adds a LUT, resulting in a file that is way too contrasted.
    If I go in Refresh Sequence and Remove Color Adapters, the rushes with the burnt in LUT come out very contrasty too (the one with source settings come out normal).
    I can’t figure out how to export a file that looks like what I see while editing.
    Help would be much appreciated!
    Many thanks
    Simon Birman replied 7 years, 6 months ago 2 Members · 2 Replies
  • Pat Horridge
    March 27, 2019 at 7:30 am
    How exactly are you exporting from Avid?
    If its QuickTime and then you chose custom and then a codec like H264 there will be your problem.
    Mixdown to desired codec then export Same As Source. If need. E then transcode externally.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
  • Simon Birman
    March 29, 2019 at 7:27 pm
    Hi there,
    Thanks for your answer.
    I’ve tried various exports, including same as source, with the same problem.
    The mixdown technique doesn’t work.
    The only way I found was to change the color settings from YCbCr 709 to RGB 709/S-Log3, export same as source (which takes hours of rendering) and then transcode externally. Hardly a viable solution if I’m exporting a feature length film.
    Any ideas?
