Activity Forums DaVinci Resolve On edit window- mixing two audio channels sounds bad in the final export
  • On edit window- mixing two audio channels sounds bad in the final export
    Posted by Evans Briceño on October 8, 2014 at 4:27 am
    I remember on FCP and Premiere Pro when you playback the sound edit on preview and your mix ( when two dissolves met) sounds jitter.
    So I hear that in resolve 11.1 in preview and in the final mix. Using two channels only.
    there is no way to get rid of that jitter, no changing the dissolve’s time, point of encounter. Nothing.
    I don’t know if I need to ingest another kind of sound codec. I have not try that yet.
    Any about this? someone with this same situation?
    Evans Briceño
    BLUE films
    Caracas, Venezuela.
    VZLA. +584166352066 / +582122838114 / USA +1-718-673-3326
    virtualevans@gmail.com / contacto@virtualevans.com / http://www.virtualevans.com
    Evans Briceño replied 11 years, 10 months ago 2 Members · 2 Replies
