Activity Forums DVD Authoring “on-disc” shortcut to files
  • “on-disc” shortcut to files
    Posted by Shane P on July 30, 2007 at 12:07 am
    I’ve got a DVD with some ROM content which consists of a website – on the disc.
    To launch the ‘on-disc’ website, I’ve created a shortcut on the disc that will link to the ‘index.htm’ file. (If I move and rename the original ‘index.htm’ file, it breaks the website, so that’s not an option.)
    The problem is this…when I create a shortcut to the index.htm file, the shortcut path uses the drive letter, which is usually D, but not always. I need to create a shortcut path that utilizes the name of the disc, instead of the drive letter, in order to bulletproof the disc.
    Any takers??
    thanks,
    sp
    Shane P replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
