Activity Forums Panasonic Cameras on camera lighting
  • on camera lighting
    Posted by Matt Campbell on July 27, 2009 at 8:30 pm
    I’ve searched the forums for on-camera lighting for the HVX 200 and am not having much luck. Can anyone recommend a good on-camera lighting kit for this camera? We are in need of a camera light for some night-time man on the street style interviews. Nothing fancy or expensive. Just something good that will get the subject lit. Similar to what on the scene news reporters would use.
    What do I need to consider as far as powering the lights?
    Any suggestions? Thx
    OS 10.5.5, Mac Pro 2 x 3 ghz quad-core intel xenon, 9 gb ram, with BM Intensity Pro card
    John Fishback
    replied 17 years, 1 month ago
    5 Members · 7 Replies
  • 7 Replies
  • Steve Eisen
    July 27, 2009 at 10:26 pm
    I don’t believe you did not find anything. This question has been asked many many times.
    Here are a couple lights to get you started.
    Lite Panels Micro Lite
    MicroBeam 128
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Trevor Ward
    July 27, 2009 at 11:43 pm
    Lite Panels Micro. about $250. Great as long as your less than 10 feet from your subject. Runs off 4 double A batteries.
    -trevor ward
    Red Eye Film Co.
    http://www.redeyefilmco.com
    orlando, fl
  • Jason Jenkins
    July 28, 2009 at 12:13 am
    I’ve used the Lite Panels Micro several times and it’s better than nothing… but not by much. Low output, (with a spotlight effect) which dims significantly over the hour that your battery will last. You could try this: https://www.flolight.com/catalog/product/view/id/53/s/miclight/
    It’s probably just as bad -for only $150!
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
  • Trevor Ward
    July 28, 2009 at 12:28 am
    Well, to be fair, how many “on-camera lighting” setups don’t give you the spotlight effect to some degree. That’s the nature of a small light, in front of your subject. If you can put the light on a stand, off center, then it’s better. Or perhaps give it to your PA/grip to hold. Small budgets means you make sacrifices.
    I’ve also used the small Frezzi. They have proprietary batteries and charges. Or at least they are not standard AA types nor are they regular prosumer camera battery friendly. They have a big longer throw than the lite panel. they get hotter too. Or, you could get the lite panel Mini which is bigger and gives way more light, at around $450. Still runs on AA’s.
    -trevor ward
    Red Eye Film Co.
    orlando, fl
  • Matt Campbell
    July 28, 2009 at 8:05 pm
    Sorry about that. Maybe I was in the wrong forums cause all i was finding was about lighting kits vs. actual on-camera lighting. Thanks for your response. The lite panel one seems to be pretty popular. Appreciate the help.
  • Matt Campbell
    July 28, 2009 at 8:07 pm
    Thanks all for your help. I’m leaning towards lite panel. Unless by the graces from above we get more money for better lights. appreciate it.
  • John Fishback
    August 1, 2009 at 7:08 pm
    Checkout Anton Bauer Ultralights. They’re not lcds, but are excellent on-cam units. You can get some very good deals on eBay. https://www.antonbauer.com/Products/Categories/Ultralights
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
