Activity › Forums › Adobe After Effects › On a deadline and stuck! AE color interpretation problem
Walter Soyka replied 10 years, 10 months ago 5 Members · 23 Replies
Kalleheikki Kannisto
November 23, 2015 at 10:40 amBased on John’s theory you might be able to counteract the contrast effect by adding a Brightness/Contrast Effect with the settings -8,6 contrast, -1 brightness, Use Legacy Mode box checked. While not an answer as to why the shift is happening, maybe some such workaround will allow you to get through the current job and then research the matter further when not under a deadline.
Jim Arco
November 23, 2015 at 12:47 pmWalter (and Faith,)
It is my understanding that the contrast problem shows up upon import, suggesting that something related to import is interpreting the file incorrectly. It sounds a bit like the “setup / no setup” problem from a few years ago, but I thought that was related to quicktime and had been resolved.
Photoshop has that snakepit of “profiles” but I don’t remember anything similar in AE. Other than a codec or color management settings, what else could change the interpretation of a file?
Jim
Colorburst Video -
Walter Soyka
November 25, 2015 at 10:54 am[Faith Granger] “So kids, are you all giving up on me now????”
Never! But I try not to work on the weekends.
As John mentioned last week, the problem here seems to be an issue of video levels versus data levels [link]. With color management on, interpreting the original as HDTV (Rec. 709) 16-235 makes it an exact match for the Ae render interpreted as HDTV (Rec. 709).
Apparently, levels in Vegas is a common source of confusion [link].
Try this in Vegas:
https://www.youtube.com/watch?v=cRFAL-TJWWwWalter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn]Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
