Activity Forums VEGAS Pro OMG! Pro 11 is sooo slow. Pro 9 and 10 were Ok but pro 11 is awful. Any advice?
  • OMG! Pro 11 is sooo slow. Pro 9 and 10 were Ok but pro 11 is awful. Any advice?
    Posted by Dan Lindley on October 29, 2011 at 2:59 pm
    I can’t render my projects in 10 Pro because 11 saved the projects in a new format. I’m down to 1 sec rendering PER FRAME and I’m quite experienced with Vegas. System: Core 17 OC to 3.87 and stable. 12 GB Ram. Nvidia GPU compliant card that “shows” in Vegas for acceleration. Reading from an SSD and rendering to a HHD. I have about 90 minute projects with lots of edits, multiple tracks and nothing but a few effects. Zero color correction. It’s entirety has a green screen alpha channel with overlays of an alpha monitor and key framed (to fit) video. But I ALWAYS did this with 10 and the render would be about 4 hours. Last night, I found if I rendered (the same as the source footage) to the Sony AVC m2ts format, I DID obtain my needed 4 hour render. But this morning…changed zero settings…This “Sony AVC mt2s” choice for rendering no longer available when looking at all rendering choices. What’s up with this? MIGHT I NEED TO REINSTALL WINDOWS? I WISH HAD never UPGRADED TO 11 because the projects previously edited in 10 are not compatible any longer with 9 or 10. HELP!! Nothing is running in the background and the CPU is no higher than 27%. OMG! I have customers waiting.
    Carl Britton replied 14 years, 7 months ago 4 Members · 6 Replies
  • Dave Haynie
    October 29, 2011 at 7:00 pm
    A couple of things… probably TMI, but the take-away: GPU isn’t always faster.
    I’ve seen the Sony AVC option vanish in VP11 a couple of times. Usually ending VP11 and then starting it up again solves the problem.
    Depending on your CPU and GPU, some things can actually run slower with the GPU enabled. The problem seems to be that in GPU mode, you’re going to get your work scheduled on the GPU, but there may not be enough work for the CPU to do. And in fact, oddly enough, on most GPU renders I’ve benchmarked, I see both CPU and GPU doing lots of waiting for things. Maybe it’s just my PCIe bus speed, I don’t know (planning to look into that, I’m still tweaking my system up to optimize for VP11). No matter what you do, there’s going to be a bottleneck somewhere in the system — we’re just used to it being the CPU most of the time.
    Some real numbers for ya. Rendering to Main Concept MPEG-2 from a pretty straight forward AVCHD edit with just some contrast correction, I found Vegas 11 to be 20% SLOWER than Vegas 10 with GPU enabled. In this setup, I also found that preview was slower.. I saw 40fps with GPU, 57fps without (720p60 “PH” mode AVCHD source, HMC40 camcorder). However, compared to Vegas 10, the non-GPU Vegas 11 did 9% faster renders to MPEG-2.
    On the other hand, rendering to AVC, I found Vegas 11 to run 13% faster than Vegas 10 without GPU, 26% faster with GPU, from the same project. Go figure.
    Now, my system has an AMD1090T processor — a really fast i7 might peak at better than twice as fast. On the other hand, my GPU is an AMD HD6970, which I have found to be faster at just about everything, on my system, than the nVidia GTX570 I’ve also been testing. If you have a slower GPU and faster CPU, I think you’ll definitely find a larger number of senarios that render faster with the CPU only.
    Best results so far as with lots of PNGs and less video. The published Sony VP11 Benchmark rendered to Sony AVC 118% faster on the HD6970, 52% faster on the GTX570, than non-GPU Vegas 11. Oddly, I saw an average CPU use of 58% and GPU use of 30% for the HD6970 render, 75% CPU and 50% GPU for the nVidia render… still trying to figure that one out.
    -Dave
  • Dan Lindley
    October 29, 2011 at 9:21 pm
    Thanks Dave! Definitely NOT TMI. I need all the help I can get. I thought I had pro 10 all figured out but these new obstacles are getting the best of me. Is it possible for rendering as AVC (with GPU optimization) that (even though I have a Nvidia GTX560Ti 2Gb) the video card is not really good enough and it may be acting as a bottleneck. It is recognized by Vegas when I choose GPU rendering but maybe that’s irrelevant? Thus, CPU rendering is better on my system? Again, thank you VERY much. Dan…
  • Ken Mitchell
    October 31, 2011 at 4:09 am
    My sandybridge 2600K renders CPU avc at about the same speed as incorporating my GPU GTX560TI
  • Carl Britton
    January 30, 2012 at 11:09 am
    I know this thread is a few months old now but I have just com across the same problem. I have just built a rendering PC for use in a school with an Intel i7 3960 @ 4.5GHz, 32GB RAM, nVidia 570GTX and WD Caviar Black OS HDD (1TB)and rendering HDD (2TB).
    I was using Vegas Movie Studio 11 HD and downloaded Pro 11 trial to see if it would render any quicker, being 64bit. The same project actually rendered 10 mins slower than the 32bit home version!
    Anyone have any ideas why this is?
  • Dan Lindley
    January 30, 2012 at 4:40 pm
    Sony has a known problem with the GPU acceleration “feature”. My solution was to toggle OFF the GPU Acceleration feature. I think that’s under Preferences (or Properties?) then the Video tab. Now all is fine and projects render VERY fast! Good luck. Hope that helps.
  • Carl Britton
    January 31, 2012 at 8:40 am
    Hi Dan,
    I did what you said and the same project rendered a couple of mins quicker in Pro than in Movie Studio so thanks for the tip. Be nice when Sony sort out the GPU issue. I could have saved myself a couple of hundred £’s and just bought a basic graphics card if I can’t make use of the GPU feature.
