Activity › Forums › Apple Final Cut Pro Legacy › OMG!! Capture files GONE
Posted by Paul Stroud on January 25, 2011 at 5:39 pmPlease help.
All of the capture files in my capture have disappeared
I’ve run disk warrior and they’re still unrecovered
If I have to recapture it’s not the end of the world, but if I can help it I’d rather not. I borrowed at dv cam for the job
Many thanks
http://www.paulstroudmusic.co.uk
http://www.stroudandcroft.co.uk
myspace/paulstroudmusicJeremy Garchow replied 15 years, 7 months ago 6 Members · 18 Replies -
Rafael Amador
January 25, 2011 at 5:48 pmHi paul,
There are many applications that lets you recover deleted files.
This is the solution when there is no other mean to recover the media.
If you can re-capture, do it. Will be easier and faster.
rafael -
Matthew Bradshaw
January 25, 2011 at 6:34 pmWhat Jeremy said … There are often several Capture Scratch folders.
Matt. -
Paul Stroud
January 25, 2011 at 7:39 pmWell, it looks as though I’m gonna have to recapture 🙁
Just tried a data recovery app to no avail
I have only one location for scratch and capture and I know exactly where that is because I’ve use it had to find it for use in after effects too.
Oh well. Thank god the deadline is not today! Small mercies
Many thanks to you all for your help and speedy response
Incidentally – the files went into the ether during an export for soundtrack (yes that’s how close I was to being done). error message “There was an error exporting”…. then back to the project window and all files showing as “media offline”
If this means anything to anyone I’d like to hear your thoughts
Kylee Pena
January 25, 2011 at 9:46 pmIt sounds like the files were on an external that became unmounted and now it can’t find them.
Paul Stroud
January 25, 2011 at 10:39 pmI wish it were that easy
I’ve now run a deeeeeep scan. It’s found loads of deleted files (deleted months ago), but NONE of the capture files that went missing this afternoon
This is really, very weird
Used 2 different data recovery tools – nada!
myspace/paulstroudmusic -
Rafael Amador
January 25, 2011 at 11:28 pmHi Paul,
Data recovery applications are very specialized and seems that the applications you are using are designed for Audio.
Try (free trial) DataRecover or FileSalvage. They are designed to recover QT, MPEGS, JPEG and similar.
They won’t look for other kind of stuff.
If your footage was ever wrote on the HD, will find it.
rafael -
Paul Stroud
January 26, 2011 at 1:21 pmThanks Raf,
FileSalvage pretty much found the same things my other data recovery app did. So still no joy
It’s bizarre – I just don’t get it – makes no sense
Recapturing footage is going to be a new experience for me. Hopefully it won’t be cause for much grief.
I have a feeling I captured at the wrong frame rate anyway – not as daft as it may initially sound, but still a bit stupid, sure. I captured a standard def dv tape, so set up as PAL 25fps. However, it’s a super8 footage so should be, probably 24fps
I guess I’d need to tell FCP that it’s progressive too?
Some testing needed. I’m learning a lot 🙂 ha ha
Rafael Amador
January 26, 2011 at 1:33 pm[Paul Stroud] ” I captured a standard def dv tape, so set up as PAL 25fps. However, it’s a super8 footage so should be, probably 24fps”
I don’t think by mistake you can capture 24p stuff with a PAL capture preset.
In the end of the day DVp24 tapes are plain NTSC. You add the pull-down to the p24 picture to get the standard NTSC (i29,97).
rafael -
Jeremy Garchow
January 26, 2011 at 1:54 pmIt really depends on the telecine process.
In a previous thread, someone found their files in the trash. Have you checked there?
