Activity › Forums › Apple Final Cut Pro Legacy › OMFs with merged clips
Alberto Gonzalez
July 20, 2011 at 9:56 pmHi everybody. I got the same problem than Rob. I synchronized a lot of clips with “modify/ merge clip”. Now I want to make a OMF for the sound postpro. My problem now is the sound files i used for the sync aren´t the original sound files, they are just a reference for the original files, so is very important that when I will make the OMF the information about the source clip should appears (name and of course TC) but with the OMF just appears the name of the merged clip and the TC from the sequence. is there any way to get this? How can I get a AAF file from final cut?
Nick Meyers
July 20, 2011 at 11:47 pm“with the OMF just appears the name of the merged clip and the TC from the sequence”
i can understand the NAME of the merged clip appearing,
but the TC of the sequence?
that’s just weird.anyway, did you follow the steps in the guide i wrote above?
nick
Alberto Gonzalez
July 21, 2011 at 7:18 amThanks for the reply. Yes,with the OMF appears the TC from the sequence but this is normal, isn´t it? it would be weird if the information about TC from the source file will appear in the OMF, no?
I´m going to try this afternoon with your advice, but it looks some difficult and (as you can see) I´m not very good with the english language 😉 btw your help is very appreciate. thanks !
