Activity Forums Avid Media Composer omf to mxf
  • omf to mxf
    Posted by Css Jason on December 6, 2007 at 5:43 pm
    Just recently started doing most projects in mxf, but often need to rebuild old projects that used the omf media type.
    From new mxf project, opened old backedup bin/sequence and did batch import/recreate titles. Avid went through the motions but ended up re-creating the files as omf, showing up offline in my project.
    Any idesa?
    Thanks much.
    Jon Zanone replied 18 years, 9 months ago 2 Members · 1 Reply
  • Jon Zanone
    December 7, 2007 at 12:12 pm
    Try changing your project type to OMF in settings / media creation? I don’t believe you can open an OMF project in an MXF project, and vice versa…
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
