Activity Forums Audio omf to aaf
  • omf to aaf
    Posted by Frédéric on August 30, 2007 at 9:35 pm
    hi,
    maybe you audio proffesionals can help me, i hope so
    i’m looking for a way to convert an omf session with embedded audio to aaf with embedded audio
    i was thinking about protools, or is there other software that can do this?
    protools can import omf – can it output an aaf session of this omf?
    does protools need a plugin for this? fe digitanslator?
    any tips would be greatly aprreciated , i need omf from a fcpro system into a ppro system, and ppro does only work with aaf
    thx, Fr
    Frédéric replied 19 years ago 2 Members · 2 Replies
  • Lee Grainge
    September 3, 2007 at 11:11 am
    Hi there,
    Pro tools does indeed do what you need to. Digitranslator will convert OMF to AAF – I cannot remember exactly but I think Logic also does. Well I have in the past imported an OMF into Logic Pro. The importer in Logic VERS 7.0 seemed to not be able to read all the order that Pro-Tools wrapped them. Basically some files were not in the T/C position they should be.
    I originally bought Digitranslator 2 (do not buy with VERS 1) then soon realised that I needed the DV Tool Kit II which has this and many other options that you normally only find on the HD series of PT.
    I don’t know about any other Apps.
    Hope this helps.
  • Frédéric
    September 3, 2007 at 11:49 am
    ok thx Lee,
    i have a friend with protools ans digitranslator so i will doe the test
    Fr
