Activity › Forums › Apple Final Cut Pro Legacy › OMF that are bigger than 2GB
Posted by Ling Lee on October 23, 2009 at 9:37 amHello,
Final Cut 6 doesn’t support OMFs that are bigger than 2gb. I just finished a 70mins feature length documentary.
Does anybody know how else I could make OMF’s.
LingMichael Gissing replied 16 years, 11 months ago 4 Members · 3 Replies -
Anders Haavie
October 23, 2009 at 10:26 amJust unselect half of the tracks, make OMF.. the reselect the unselected tracks. Works great. We do it all the time with broadcast stuff.
Anders
Xraid-Xserve-Xsan-Xeverything
John Pale
October 23, 2009 at 12:24 pmThis is not a FCP limitation. The OMF format does not allow EMBEDDED OMF files to be larger than 2GB. This limitation exists on Avid too (however you can get around it by linking to the media instead of embedding in many circumstances…this feature is not offered in FCP). Just break up the sequence in a logical way (by tracks or acts) and reassemble in ProTools or whatever you are using.
Michael Gissing
October 23, 2009 at 9:15 pmAsk your sound post people how they want it broken up. Personally I prefer chunks not a bunch of tracks.
FCP ignores In/Out markers when making OMFs do I recommend you duplicate sequence, delete the second half and make an OMF. Don’t save at this stage. After the OMF is made hit undo and then delete the first half. Make the second OMF and then exit without saving.
By doing it track by track, many systems import the next OMF and default the tracks to tracks 1&2, overwriting or overlaying existing material. Also by doing it in segments, the tracklay can start on the first half of the program whilst waiting for the second half to arrive via ftp for example.
