Activity Forums Apple Final Cut Pro Legacy OMF Sync issues
  • OMF Sync issues
    Posted by Louis Basslines on March 18, 2013 at 1:19 pm
    I have some footage on a timeline which is 29.97 however I do have few cuts on the timeline which are 25FPS. My session is at 29.97. All audio is synced on timeline and sounds good. I have exported an OMF. When I open in protools the audio is in sync with the reference mp4 video export. When I import my protools mix bounce back into FCP it is drifting out of time. I believe the omf protools project should be the same setting as my FCP setting however the protools session must have a setting out for my bounce to be a different length. Any hints appreciated.
    Macbook Pro 2.8Ghz Intel core duo 4GB ram OS10.6.6
    FCP 7
    Louis Basslines replied 13 years, 6 months ago 2 Members · 2 Replies
  • Nick Meyers
    March 18, 2013 at 2:39 pm
    this seems to come up a lot,
    check your sequence pre-set in FCP a/v settings.
    it needs to be the same frame rate as your working sequence and PT bounce.
    if it isn’t, you can get drift on imported audio.
    nick
  • Louis Basslines
    March 19, 2013 at 1:52 am
    Nick, thanks for you helpful reply. Yes that was precisely the problem. All syncing well now thank you.
    FCP 7
