Activity Forums Avid Media Composer OMF imprt results in slowed-down audio speed
  • OMF imprt results in slowed-down audio speed
    Posted by Sebastian Riezler on July 24, 2006 at 12:35 pm
    Hi there,
    I imported an OMF 2.0 File in my MC1000 V12.01.
    It is imported at 44.1kHz but my project is in 48kHz. Are there any options to change this parameter berfore importing? I couldn’t find any options then to convert samplerate after importing.
    When I play the soundfiles they are played way to slow.
    Does anyone of you know a solution for this problem?
    thanks for answers
    RiotManZ
    Jon Zanone replied 20 years, 1 month ago 2 Members · 1 Reply
  • Jon Zanone
    July 25, 2006 at 11:31 am
    Look in the audio settings – you should be able to set your overall setting, as well as what to do when Avid encounters different sample rates.
    I’m not in front of my machine right now, but there should be a transcode (I think it was called something different in the MC) in the clip menu….
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
