Activity › Forums › Apple Final Cut Pro Legacy › OMF for audio sweetening
Posted by Chris Poisson on January 23, 2008 at 9:14 pmI’ve never done one of these before, is there anything I need to be wary of?
Simple talking head 5 minute show, my sound guy wants an OMF to clean up some noise and whatnot, project is 720p.
Have a wonderful day.
Chris Borjis replied 18 years, 8 months ago 3 Members · 3 Replies -
Paul Escandon
January 23, 2008 at 9:30 pmIt’s pretty straight-forward. Make sure that none of the audio tracks are disabled unless you don’t want those appearing in the OMF.
You only have a few options in the OMF export settings – audio bit rate, depth, and handle length (at least in 5.1.4 this is the case).
Final Cut improved their OMF export in version 6 to allow any keyframing you did to be carried over. If you’re on an older version of Final Cut keep in mind this data won’t transfer.
It might be a good idea to render a low res quicktime for the Pro Tools guy to load into his system. I usually work in HD but render a DV quicktime for the Pro Tools guy to work with here.
Paul Escandon – Lead Editor @ Outdoor Channel
Producer | Director – Oremus Productions
http://www.oremusproductions.com
Apple Certified Trainer – Final Cut Pro
Adjunct Professor of Media – JPCU
MacPro Quad-core XEON
8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD -
Chris Borjis
January 24, 2008 at 10:31 pmmake sure to include the handles I think it defaults to 1 second which is fine.
and like Paul mentioned, do include a DV quicktime of it and add a timecode window that matches your timeline just in case.
