Activity Forums Adobe After Effects OMF Export/Import Problems
  • OMF Export/Import Problems
    Posted by Dale on June 15, 2005 at 7:31 am
    Hi I am trying AE 6.5 standard for the first time- got the compostion done as i want but i am having trouble actually finding where i can change the output setting to OMF for Avid exppro. I tried where it says in the help menu, in the output module, but OMF is nowhere to be seen. I tried to Export out of Avid as an OMF but when i import this file into AE nothing happens. What am i missing here?
    Dale replied 21 years, 3 months ago 3 Members · 4 Replies
  • Mylenium
    June 15, 2005 at 8:34 am
    OMF is only available in the Professional version, methinks. Why don’t you just create a reference Quicktime movie (assuming you use AE and Avid on the same system).
    Mylenium
    [Pour Myl
  • Yves De muyter
    June 15, 2005 at 8:43 am
    Isn’t this what “automatic duck” is used for ?
    As far as i know, AE cannot export or import OMF. The best workflow i’ve found is to export you composition into a Quicktime REF file, and export from AE into a .AVI with Avid codec.
    -Yves
  • Mylenium
    June 15, 2005 at 9:03 am
    Automatic Duck will of course do the trick plus it will keep some effects, transitions and nested timelines from Avid, but you should be able to get a pure video/audio OMF file into AE Professional. The import option is there, but I don’t know how successfully it can be used ‘cos I never tried. Anyway, if he has only AE Standard, he’s out of luck in this case.
    Mylenium
    [Pour Myl
  • Dale
    June 16, 2005 at 5:50 am
    So standard won’t do the job- generally if u look around AE it will specify if the effect is for “pro only” thats what made me think it was possible as it doesn’t specify that anywhwere. I will try a few things to see what i come up with with the QT etc…
    Thanks and regards,
    Dale…
