OMF export problem with multichannel wave files…
Hello!
I’ve been dealing with a strange situation at the moment of sending audio material.
The project has several audio tracks. It works with multichannel wave files most of the times.
The OMF (encapsulated or not, it does not make any difference at all) Premiere CS 5.03 exports from the sequence fails to keep all the audio channels available.
I cannot find a way to fix this.I’ve seen the same problem in a project which worked with R3D files with also 4 channels of audio.
Is this a common problem? Any solution or help with this matter?
Thanks for your time in advance!!!!
